Rotary Chic
sounds like its time to rebuild
Turtle Yes I am a girl and I will kick your butt. Prove yourself. |
I do believe you guys, but does it sound like i did it right?? and would the pulses be even if compression was bad? could it be in the intake? I have no idea.
crash auto?fix auto
Was the engine warmed up when you did the test? Otherwise everything else sounds pretty good as far the tests execution is concerned.
Although those are low numbers even for a stone cold engien that is in decent shape.... |
