Rep Power: 21 ![]() |
from doing a little research and remembering some forgotten chemistry, i believe distilled water INCREASES the rate at which corrosion will occur.
Rep Power: 20 ![]() |
I thought distilled water was just straight H2O... If you can't use distilled water what are you supposed to use? 50/50 premix? I imagine 50/50 premix that has "Safe on Aluminum Radiators" on its label would be fine. But what if you want to mix your own stuff? maybe go 80/20 or 70/30 or any other which you want?
Bookmarks |
