Rep Power: 21 ![]() |
UPDATED PICTURES!!!!!!!!
OKay so last night was productive to say the least AND i still had time to go cruisn' with some local folks. The water pump problem has been addressed. Went back to an FB housing. The belt is on, alt is set etc. No clutch fan since i have one belt. So i am going to commender a e-fan on a junk yard visit. The batt. cables are all hooked up. Used an old FC brake line for the clutch cable. Bleed that. Only problems are once i got the batt. installed and went to crank it, the start just clicks alot and doesn't do anything. I think i saved the bad starter i did on my friends Rx7 and for some stupid reason, it ended up in my car.... So this weekend i am going to plumb the FPR, deal with the starter, maybe finish the exhaust. And hope to see it start!! ![]() ![]() ![]() ![]()
