#11 |
The Idle is set to 900 rpms that hasn't changed, the car just will not stay at that rpm by itself. It got to around 77C before i turned it off, barely running and smoking the whole time. The vacuum line was plugged into the map sensor, but I will check for leaks. The air pump is on and plugged in, I still have my main cat. I will have to look into the crank angle sensor, do you have a picture of where it is located by any chance?
Regards Mike |
