Old 08-07-2008, 07:04 AM   #1
Kentetsu
Kentetsu's Avatar
Originally Posted by PercentSevenC View Post
How do you like the spring rates you got from a racing perspective? Are the rears stiff enough?
The ride as a daily driver is pretty good. It will knock you around a bit at lower speeds going over rough intersections and such, but the street performance makes up for any discomfort.
For racing, it simply kicks ass. I see a lot of guys running much higher spring rates for autocross, and I just can't understand it. I can't see how there would be any benefit from it. My car has practically zero body roll, as you can clearly see in my more recent videos, and weight transfer is instantaneous.
For the rear springs, I may end up having to go slightly higher in spring rate to get a little more reduction of understeer. Not sure on this yet, I need a couple more races in to be sure.
coilovers
