Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > BNR Turbos
BNR Turbos www.bnrturbos.com (AL) Custom and rebuilt turbochargers
Old 07-28-2008, 10:29 PM   #1
Bryan@BNR
Bryan@BNR is on a distinguished road
Originally Posted by rotarycrazy View Post
you have stated a chiped ECU where can I get that done becouse rteck only does S4 turbo and NA S5 also someone told me that S5 ecu will not work by itself that it need to see the remainder of the wiring or it goes into limp mode is that true.
A stock ECU will work good. You will need to pull around 6 degrees out of the timing and then get some 720s with a Super AFC 2 along with a FCD. Then with all the other mods, you should be good for 12-13 psi of boost. I would definatly install an EGT gauge to monitor those exhaust temps, then you will see how much room you have to adjust your timing up or down with the crank angle sensor. Also just as crutial is your AFR's. Make damn sure to keep the engine running pig rich and don't run more than 11.4 AFR at full boost. You may be able to run more boost, but definately keep an eye on that tuning b/c you can ruin the engine in a second if you dont know what you are doing...
Bryan@BNR is offline   Reply With Quote
Old 07-30-2008, 05:30 AM   #2
Boostmaniac
There was more factual wisdom in this paragraph than you will ever know. I think all TII owners should memorize this before modifying their cars.
