| 3rd Gen RX-7 Cars For Sale Buy or Sell your Car only!! No Parts! |
I have just put up a one owner RX-7 with over $22,500 invested in it on eBay. It has every single receipt since it rolled off the showroom floor, literally a seven inch stack of receipts. The link is below, if you are interested in purchasing it please shoot me an email or call me at (832)483-5281.
Thanks, Ryan P.R.S. Cars http://cgi.ebay.com/ebaymotors/Cars-...3756.m14.l1318 This particular example may be the most amazing of them all, a one owner since new RX-7 with over $22,500 invested in it! The car has a clean Texas title and a Perfect CarFax. When we purchased this car, the one and only owner (an engineer) provided us not with just a couple of receipts, but with a huge file folder full with every single receipt since the car rolled off the showroom floor, 14 years documenting every oil change, every dealer service, every tire rotation, every part, everything. Please see the pictures to help understand the depth and detail of the records, from the original window sticker, to its most recent oil change. Additionally, before we purchased this amazing car we had it taken to the Mazda dealer where a trained rotary specialist examined every nut and bolt of the car for 3+ hours and gave it a shining report. This RX-7 has been meticulously maintained and very pampered, spending the last few years garaged and only taken out in perfect weather. The factory Bose stereo has been rebuilt and works perfectly. The wheels show no curb rash. The interior is fantastic for the year. There isn't a door ding on the entire car. The paint is nice and shiny thanks to a re-spray. The tires are brand new. To top it all off, the RX-7 only has 400 miles on the new motor, completely rebuilt this year. The one owner went through great lengths, and great cost, to upgrade and replace everything, resulting in a car with over 400 Horse Power that is more reliable than a Honda Civic. The modifications to the RX-7 have all been top quality, the best money can buy, and very well chosen to provide greatly enhanced reliability and added power that you can live with every day, this truly is an RX-7 like no other: Rebuilt engine with New rotor housings, New bolts, and ALL NEW seals including apex seals. Factory rebuilt transmission - new syncros and bearings. New Genuine EFINI TURBOS. Efini Y-pipe. Peter Farrell Supercars PMS computer with 3 map switch under steering column and hand terminal in glovebox (Currently set to 10, 13, and 16 pounds of boost equaling approx. 315-445 HP). ACT High Performance clutch. Custom PWR polished aluminum radiator with center feed top pipe and stainless hose pipes. Greddy Airinx dual air intake system with K&N filters (the The Blue Airnix foam filters were replaced with the K&N's cotton because the K&N's filter much better). Greddy 24V intercooler. Polished Greddy air tank. Mocal 11" oil cooler with thermal bypass. Silicone vacuum tubing throughout. New turbo control and wastegate solenoids. New fuel injectors, fuel pressure regulator, and pulsation dampener. New oil injectors and injection lines. Walbro 255 L/Hr fuel pump. All new exhaust - 3" stainless from turbos to tailpipe with 3" Bonez rotary specific catalytic and Thermotec wrap. Passes emissions with room to spare! Custom aluminum belly pan, radiator, cross member, and air separation tank brackets. Braided Stainless hoses on water lines and Greddy catch can. Earl's Oil lines with A/N fittings. Autometer A/F and Boost gauges in column pod with light dimming tied to dash lights. Trunk relocated battery. Rotary Performance aircraft aluminum trailing and toe control links (rear suspension). New Bridgestone Potenza's (<1k miles). Tokico Illumina adjustable shocks. All fasteners replaced with stainless. New AC compressor, alternator, water pump, rack and pinion and thermostat. The list goes on and on and on... |
