Old 09-11-2017, 02:55 PM   #1
WankelsRevenge
WankelsRevenge's Avatar
After picking up the car decided to do as much work as I could to it before swapping the motor and trans over. Picked up some cheap MaxSpeed coilovers a bunch of the other local guys were using and had good luck with. Just seems the biggest thing was they are heavy as hell. But install was a breeze and after playing around with them a little bit both camber and height adjustment were fairly simple. Overall for the price I'm fairly happy with them.
Summary of this thread:
Old 09-11-2017, 02:58 PM   #2
WankelsRevenge
Well since I bought the car with a fairly stripped out interior I got to work swapping over as much stuff as I could from the purple car. Though it wasn't much I moved over my seats, harness, and steering wheel. I also picked up an extra dash from a friend since the one currently in the car is broken off below the center console section.
Old 09-11-2017, 03:03 PM   #3
WankelsRevenge
Since the engine bay was pretty bare I decided to go ahead and paint the bay. My last car was bright purple, but the previous owner didn't paint any of the jambs or bay to match so the original white stuck out pretty bad. I decided to go with a simple black since it matches pretty much everything. I plan on painting the car in the future and wanted something simple that would go with it.
The below pictures are the three stages of the paint job. The first is after I cleaned/washed the engine bay, the second is after I did a layer of primer, and the last is the final black.
Old 09-11-2017, 03:09 PM   #4
WankelsRevenge
Set aside a weekend off work to get the engine swapped over. While I was at it I put in a whole new Exedy clutch setup including master/slave and hard/braided lines. Also decided to install a lightweight Fidanza flywheel since I had everything out of the car and knew I'd regret not doing it in the future.
After getting the car towed over to my house I worked on getting my RB exhaust back on, and getting my Megasquirt harness installed. I picked up a relay box from Stu Kelley Motorsports to clean up the install a bit.
