IT'S ALIVE!
Rep Power: 17 ![]() |
I pulled the engine today. This is what I found in the transmission bell housing:
I removed the clutch and flywheel to access the studs. I didn't see any other possible sources of the leak, so I removed the nuts and cleaned everything. The washers got a coating of 10W30 and I applied a liberal amount of Permatex Black to the threads of the studs. I torqued everything down finger tight and waited 15 minutes for the sealant to set up before torquing everything to 10 lb-ft. I then waiting 30 minutes before torquing everything, incrementally, to 32 ft-lb. It needs a day to cure and then I'm going to flip the engine around and fill it with water to check for leaks. Last edited by infernosg; 08-14-2017 at 08:07 AM. |
#2 | |
Waffles - hmmm good
IT'S ALIVE!
Yeah, I don't know what's going on with Google Photos lately. I have everything setup in a shared album but more often than not other people can't see the photo. Regardless, it's just a photo of coolant pooling in the bell housing of the transmission.
#4 | |
Waffles - hmmm good
