#211 |
Rep Power: 22 ![]() |
He has a point.
#212 |
Rep Power: 10 ![]() |
Kyle.... the answer to your problems....
Carb Than DJ can tune it and I can keep saying, Fuck yo Carb Foo!
#213 |
Can't.Make.Up.My.Mind.
Douche No. The answer to my problem is Haltech.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
#214 |
MoTeC 》AEM > Helltech > Microwrech
#215 |
$$$$ > $$$ > $$ > yahtzee
#216 |
Rep Power: 13 ![]() |
#217 |
#218 |
Gold Wheels FTW
The 8 goes into the body shop this weekend... They think they can get it done in time.... we'll see. So much to do and no time.
Engine swap starts in July.
My Cars: 1974 RX4 Coupe 1991 FC3S RX7 - Sold 2003 ZZW30 MR2 (Rotary swap after RX8) 2004 SE3P RX8 (20B Swap in the works) |
#219 | |
Shit, Charles and Adler painted the Miata on Tuesday, and we took it to DGRR on Thursday.
#220 | |
Petes car was up on stands in my shop a few weeks ago. Harness is 1/2 way done. Plan is for him to take it on 03/12, and then head back up two weeks later after it's completelt broken in and we can tune it. It's a rush but should be able to get everything done in timeLSX?
#221 | |
Gold Wheels FTW
NA Semi PP 20b. 350~400WHP range hopefully. Engine purchased... It's happening for sure.
#222 | |
I'll buy it from you and make it into something awesome. DJ knows what I'm talking about ![]()
#223 | ||
You will then install the harness and set the base map. Peter breaks the engine in and then drive or trailer the car to you and have it tuned. Kyle has to buy an haltech and all the sensors. I would think you would charge him some money to build the harness He then has to install a harness that was built remotely and hope that the length and sensor are in the right place. I know you can get it close. Not sure if the harness will just be plug and play either. Got to wire in power, ground, prob fuel pump power,speedo and rpm. Once everything is connected and it doesn't start, he has to rely on a few local friend to come over and help or call you. I sound like a big pessimistic and hope it all works out if Kyle goes Haltech but i don't think that's his answer to his problem. |
#224 | |||||
Few minutes to get the basemap loaded and the thing running. I'm driving and tuning an FD now that is incredibly similar to Pete's engine. Should need very minor adjustments before he can make the 200is mile run back to MD next weekend Quote:
I have a PS2k harness that I could finish up in a day and sell to him with all the sensors needed. Integrating it to his S5 would be slightly time consuming though, like maybe a day to feed it the power, ground and turn on's that it needs. Quote:
I told him that too.... at this point the helltech is nothing more than a really expensive piece of diagnostic equipment. Of course I could be wrong and the helltech will fix everything, but I suspect that there's a mechanical problem, or electrical, that hasn't been found yet.
#225 |
Poor Kyle.
