Old 01-01-2017, 05:33 PM   #1
JL1RX7
Sounds like you answered your own question. Premix.
Only other option would be the Sohn(sp) (Rotary Aviation) adapter for adding the premix.
If you are using an aftermarket controller if it has an extra digital output for straight on/off control for a pump, or if you are lucky an analog output that is variable.
Old 01-01-2017, 07:13 PM   #2
Pete_89T2
Pete_89T2's Avatar
If your ECU can drive it, I'd go the electronic OMP route. You'll need to swap in an S5 front cover as well.
