#16 |
Waffles - hmmm good
The SAs have the tach signal on the leading because the stock ignition disables trailing on
certain conditions. Your car looks fairly stock so I would say it probably works this way. I bet your alternator is just weak. I've seen the dash lights stay on like that if the voltage is not good sometimes. Have you checked the battery cables yet? They may be original and falling apart internally. You're having fun now! I'm jelly. I'll take a look at my haynes manual to see if it has any extra words on dealing with the regulator.
1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00 Last edited by t_g_farrell; 07-27-2016 at 07:32 AM. |
#17 | ||
IT'S ALIVE!
Rep Power: 17 ![]() |
My battery is only outputting around 12V as it stands so I may just throw it on a charger to see if that helps any. When the car is off I'm getting the same voltage at the alternator terminal as I am across the battery posts so I don't think it's the wiring. |
#18 |
Plate Spinner
The symptoms you are getting are the same as when I broke a belt on my 79, so I would check the harness connectors from the alternator to the voltage regulator, and the regulator to the instrument cluster. they might be corroded enough to drop the voltage below where the regulator can see it. It might have gotten jostled around during shipping?
#19 | |
IT'S ALIVE!
The car won't be going anywhere for a while as I've got the steering column pulled apart to replace the upper bushing, which had crumbled to pieces causing play. Update: I took the alternator to Advance Auto Parts (don't judge) and their machine failed it. It looks like one or more diodes in the rectifier are bad so I'll be ordering a replacement from RockAuto. I still don't know if the regulator is also bad but this is a start. Last edited by infernosg; 07-27-2016 at 11:52 AM. |
#20 | |
Rep Power: 20 ![]() |
I must say I'm a little biased since I worked for the company for five years, best store in the district too
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#21 | |
IT'S ALIVE!
Yesterday I verified the display and all its connections checked out. I've got a couple more grounds to check but it looks like at least the alternator is to blame. I'm thinking the alternator isn't outputting enough voltage to cause the voltage regulator to kick in, which causes the idiot lights to go out and the tachometer to activate. I won't be able to determine if the regulator is bad until the replacement alternator comes in. |
#22 | |
Waffles - hmmm good
rockauto and they are prone to handing out unwanted and wrong advice about my car and the fact that they try to upsell you on everything. No, no issues. I go to the bricks and morter stores only under duress. Heres the process to select the store to goto: Is it a specialty part or something needs to be fabricated, CarQuest/NAPA because they can do things usually close to right and here they do some of this for the race shops so they have a clue. Otherwise its like this: Oriellys - not bad and have good stock AdvanceAuto - I can walk to it so sometimes it wins, the dog likes to go there AutoZone - desparate, only if I see they have and the other two dont WalMart - to get cheap consumables oil, etc PepBoys - never
#23 |
Yes and Yes!
#24 |
Professional Stick Poker
Mine was the same way when I got it. The bushing was little bits and pieces, that which wasn't powder. I solved it by going down to a bearing specialty place and was able to source a metal bearing that fit the steering shaft. It was slightly large on external diameter so I had to do a little filing on the plastic for the turn signal piece and used a socket to expand the metal tube slightly so the bearing would slip in. It is solid and turns easily now. No more slopping around when you try to turn the wheel.
#25 | |
IT'S ALIVE!
#26 |
IT'S ALIVE!
It turned out to be the alternator. Threw in the reman'd unit from RockAuto and everything worked as it should. Well, except for the speedometer, but that was because I forgot to reconnect the cable after inspecting the dash.
#27 |
Awesome
