Old 07-12-2016, 09:11 AM   #29
RotaryBC
RotaryBC is on a distinguished road
Put the #2 plugs back in, pull th TB off, pull the EGI fuse and crank the engine over and LISTEN very carefully
I did what he said?
The fuse is marked IG on mine, I did find what I think is a relay that is marked EGI.
I pulled the TB and the fuse marked IG, put compression tester in Top #1 plug hole, spark plug in lower #1 plug hole, I put plugs in #2.
Connected battery
depressed clutch peddle
depressed accelerator peddle
Turned the key
Nothing, no click, nothing
2005 RX-8 Shinka 171
2005 RX-8 Shinka 1137
RotaryBC is offline   Reply With Quote
