Old 07-10-2008, 06:26 PM   #1
P71
P71's Avatar
OK, here's the skinny. There's a very easy and cheap way to convert without having super-expensive custom adapters machined.
First, you'll need "wobble bolts":
http://www.ezaccessory.com/PCD_Varia..._p/98-0048.htm
This will allow you to do 2 things. One, install correct offset 4x108/4x4.25 wheels directly to the SA/FB brakes. And two, will allow you to use this:
http://www.ezaccessory.com/Wheel_Ada.../4425-4425.htm
It's just a 4x4.25 to 4x4.25 adapter BUT it has the proper width to allow you to run FWD/modern offset 4x108/4x4.25 wheels (using the wobble BOLTS to bolt the adapters to the brakes and regular tapered lug NUTS on the built-in studs, opening a HUGE amount of aftermarket wheels!).
These same guys also offer a 4x4.25 to 5x114.3 adapter and a 4x110 spacer. They will also special make a 4x110 to just about anything adapter (but realize that that will be more expensive.)
So have at it!
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
