Old 03-03-2008, 08:48 PM   #1
fikren
fikren's Avatar
fikren is on a distinguished road
Next you want to fit in the AutoExe bar. This may take alittle work to get it seated properly. Also you want to make sure that the clipped wires and the clipped washer fluid line are on the front/top side of the bar not behind. I belive when I tried it behind it put to much of a strain on the lines as they just are not long enough.
Once you have it set you want to use the supplied black backing plates and the 14mm supplied bolts (1 per side) and the 10mm supplied bolts (1 per side). The black backing plate goes up inside the fender, run the bolts through the autoexe strut, through the body, through the backing plate and put the nut on them. The 10mm bolt will be the forward most bolt the 14mm bolt will be the closest to the firewall.
Get them started on each side, crank em down. You will probley want to go back over them a couple of times to make sure none have losened up.
Picture 1-fitted Strut bar
Picture 2-bolted in engine bay side
Picture 3-inside the fender with backing plate and nuts
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
