Closed Thread
Old 03-14-2016, 04:00 PM   #1
Barry Bordes
Barry Bordes's Avatar
This is for the guys building their own engines.
An engine built anywhere in the world will be capable of making approximately the same power if the builder uses good tolerances and has a close attention to detail.
This includes engines built by Jonathan, Carlos, Alex, Tom, Brian, Howard, Peter and you Ted....(if you don't see your name I can add it!)
There should be no hero worship for anyone special. Forget the hype.
Your simple practice should be...
1- make the best possible sealing points... hence the zero-clearance side seals.
2- give the apex seals a flat surface to run-on using something like my sparkplug area cooling mod.
3- Make the AFR's spot-on with help from something like my free Excel AFR Corrections Program or any other autocorrect system.
4- And probably the toughest... center the combustion peak-pressure around 45 degrees atdc. This is where most people fall short... they go for what is called a safe ignition map.
If you follow these simple ideas you will have the highest horsepower possible at what ever boost you run, even NA.
Barry Bordes is offline
Old 03-15-2016, 10:04 AM   #2
knonfs
knonfs is on a distinguished road
Barry, what do you mean by #3?
Make sure its not too lean/rich under boost? all parts of the map?
knonfs is offline
Old 03-19-2016, 04:18 PM   #3
Barry Bordes
knonfs,
This is what the Excel program looks like.
send me a PM and with your email and I can send you a copy.
Most people don't understand the importance of an ideal mixture and it's to improvement to the burn rate.
Then on the second folder you take your corrected base map and check it any anomalies.
Barry
Old 03-16-2016, 01:30 AM   #4
Too complex...
1) Strap car on dyno
2) Adjust fuel maps
3) Adjust ignition timing maps
4) Go back to #2 and #3 until you're satified
This is how I tune my cars for highest horsepower, even NA...
Oh, here's a secret: this works for piston engines too...
RETed is offline
Closed Thread
