Old 03-03-2008, 08:30 PM   #1
fikren
fikren's Avatar
fikren is on a distinguished road
Front Strut Bar Install
I got around to installing the front AutoExe strut bar this afternoon.
Tools needed:
14mm sockets
13mm sockets
10mm sockets
Something to cut plastic with, I used a dremel with a cutting disk
Starting out you you want to remove the engine cover and the factory strut bar. The factory strut bar will use a 13 mm socket to remove the four nuts (2 per side). Once the bar is removed you then need to remove the plates that the bar sat on, 3 14mm nuts per side. You will need to hold on to these 6 14mm nuts as you will reuse them
Picture 1-stock engine bay
Picture 2-engine cover removed
Picture 3-red circled bolts are the 13mm to remove the strut bar, blue circled bolts are the 14mm to remove the plates.
Picture 4-stock strut bar and plates removed
Picture 5-the stuff you should have ended up with after you took it off.
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
