Old 03-08-2016, 12:13 PM   #61
What jalopy are you working on now DJ?
You'd have to be more specific, as everything I own could be described as a 'jalopy'.
It's easier to say that an S4 NA engine is going into something that isn't an FC.
Old 03-08-2016, 12:15 PM   #62
So you need to install a motor too
Old 03-08-2016, 01:07 PM   #63
Indeed. Although mine is much simpler than yours. Stupid FD.
Old 03-08-2016, 01:16 PM   #64
Nothing as of yet, just sifting through all the BS I need to de-pin. Also need to figure out a circuit to power the ECU, coils and fuel pump.
Looks like to run the engine I need to keep these circuits:
-AFM
-AIT
-Coolant temp
-O2 sensor
-Fuel Injectors
-CAS
-Ignition coils
-Pressure sensor
-Fuel injector/pump resistor (?)
-TPS
Right?
Don't need O2 but do need to add TPS.
I wouldn't bother with a FP resistor, although you do need them for the injectors unless you swap them
Stupid FD's.... And I've got two of them at my shop, neither with an engine
Old 03-08-2016, 01:55 PM   #65
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
DGRR registration is up to 122 today. Almost doubled in the last month or so.
Old 03-08-2016, 01:56 PM   #66
-AFM
-AIT
-Coolant temp
-O2 sensor
-Fuel Injectors
-CAS
-Ignition coils
-Pressure sensor
-TPS
Right?
Old 03-08-2016, 03:45 PM   #67
I should really find my glasses
Old 03-08-2016, 03:46 PM   #68
Your poor clients.....
Old 03-08-2016, 03:56 PM   #69
Mine is being emissions deleted and non-sequential so not too tricky.
Old 03-08-2016, 04:53 PM   #70
Still too much BS.
Old 03-08-2016, 05:26 PM   #71
Quite the opposite.. besides... I like numbers better than letters
Old 03-08-2016, 06:11 PM   #72
OMP line just snapped. F*#@
Old 03-09-2016, 09:31 AM   #73
reddozen
Gold Wheels FTW
reddozen's Avatar
Sounds like premix it is!
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 03-09-2016, 09:47 AM   #74
Originally Posted by reddozen View Post
Now that you've said that....
And this is the first year I don't have a second or third driver and the support/tow vehicle is getting left in CT
Maggie is gonna need to pack LIGHT! Actually.... might bring the track trailer... which means Hoosiers on the dragon
But the thought of towing the track trailer with the FC for 14 hours is not appealing
Old 03-09-2016, 11:01 AM   #75
Nah just ordered new braided lines this morning. Will probably do a little pre-mix too though for good measure
beer, dgrr, rally, smegma, whiskey
