|  01-29-2016, 06:39 PM | #211 | |
| Professional Stick Poker Join Date: Feb 2011 Location: Stafford, Ks.
				Rep Power: 16  | Quote:
 ... and yes I'm a cheapskate old bastard and am determined to use as much of the factory harness as I can.
				__________________ 1988 N/A SE 2+2, dead stock and staying that way.  1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 | |
|  01-30-2016, 09:24 AM | #212 | |
| Lifetime Rotorhead Join Date: Apr 2010 Location: Elkton, MD
 Your diagram should capture this minimum info: (1) What connector & pin # the wire connects to on each end - create your own connector key/labeling scheme if it's not otherwise documented anywhere in an FSM somewhere, and (2) color of the wire's insulation. Key point is to NEVER move on to a new wire until you've fully documented the last wire you were working on. That way if life interrupts the project, you have your diagram to help you pick up where you left off. | |
|  01-30-2016, 06:12 PM | #213 | |
 Proper prior planning? I no longer know you!
|  01-31-2016, 11:30 AM | #214 |
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  |   Actually... Pete nailed my biggest "issue" while wiring... If I see something that I don't instantly know what it's for, I get Squirreled. Last April while working on FrankenB, Whoop was trying to connect everything behind the firewall. Power and Gnd supplies etc, wire up the gauges shit like that. Not making it pretty, just trying to get it done enough to fire. Well... I spent a day going through that and trying to remember what everything was for. Now it's all neat, bundled shrunk and labled
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- |
|  02-01-2016, 01:50 PM | #215 | |
|  02-01-2016, 05:00 PM | #216 |
| Rotary Fanatic Join Date: Feb 2008 Location: Front Royal, VA
				Rep Power: 18  |
			Gunny they do make those things called a label maker.  Even a cheap one will do the trick.  Not just a wiring one, which can be pricey.  Now the label tape will cost you more than unit itself.  Just like printers they sell them cheap and nail you on the ink.
|  02-01-2016, 07:26 PM | #217 | |
 Rear harness is now done and strung. It is mostly hooked up except for one ground wire which of course turned out to be just short once the wire was strung where it needed to go. There wasn't quite as much room behind the tank enclosure as I thought and stringing the wire behind it was a bit of a @#$%.
|  02-01-2016, 07:32 PM | #218 |
				Rep Power: 18  |
			Murphy always says one wire will short on you.  Always in the hardest to reach spot ever.
|  02-01-2016, 08:08 PM | #219 |
				Rep Power: 16  |
			True dat. I have to pull the harness back out a ways to get at it for lengthening. It will not be an easy operation as it barely fits in there.
|  02-02-2016, 09:20 AM | #220 | ||
				Rep Power: 10  | Quote:
 Chassis harnesses are usually backwards from that Building FrankenB was backwards as well... sort of. Started with where I wanted the ECU to mount and added a few inches. Started with the injectors and ran one wire to the farthest injector, cut it. Put it on the workbench and grabbed 6 reds the same length and 5 other wires the same length. Bundled/twisted/braided together and put back on the engine at the predetermined spot where they would branch out. Took a length for the farthest coil, and repeated that process. Kept going with everthing until it was a mess of about 90 wires all ziptied together. Rachemed it, terminated it at the engine side, (that whole process took like two days) and gave it to Bawb to terminate it at the ECU side. Another 2 days of going back and forth to the wiring diagram which was visually backwards from where the pins needed to be. Once that was done I could wrap the inside part fo the harness... then lay out all the wires for power and gnd. So basically I've been working on the electrical of FrankenB for over a year now and it's still not done completely..... Quote:
 I like Gunny's idea though of the printer paper lables, that's slick Fuck that noise.
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- | ||
|  02-02-2016, 03:04 PM | #221 |
				Rep Power: 18  |
			Guessing I need to try to "expense" some label makers for you both.    |
|  02-02-2016, 03:53 PM | #222 |
				Rep Power: 10  |
			Yaaaaas!!!
|  02-02-2016, 04:53 PM | #223 | |
| ⊙⊙ Join Date: Dec 2009 Location: Great Falls
				Rep Power: 17  |
				__________________ Quote:
|  02-02-2016, 05:12 PM | #224 |
				Rep Power: 10  |
			printers?
|  02-02-2016, 05:26 PM | #225 |
				Rep Power: 16  |
