Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 01-05-2016, 07:55 PM   #26
shawnm565
shawnm565 is on a distinguished road
We have 9 Turblown BorgWarner EFR IWG Cast Manifold Turbo kits Available for sale for the FD & FC Chassis.
The Kit gives you the choice of three different size of the BorgWarner EFR IWG Series Turbo's:
EFR 7670 - $3,999.00
EFR 8374 - $4,249.00
EFR 9180/9174 $4,499.00
The kit includes the following:
* Your choice of T4 EFR 7670 IWG,8374 IWG, 9174, or 9180 IWG turbocharger
* Stainless hard line turbo cooling lines( oil feed, coolant feed/return & Flexible oil compatible heat shielded oil return line) & hardware
* 304SS TIG welded & back purged Mandrel Bent 3" V-Band downpipe with single o2 sensor bung, vband clamp and 2 bolt gasket/hardware
* 347SS Investment Cast Tapered IWG turbo manifold
* Replacement WG actuator bracket Adapter for necessary placement
* Inconel T4 Turbo Gasket, and Inconel turbo manifold studs & nuts
* Rear turbo oil return block off plate
* K&N 3.5" or 4" air filter depending upon size of the turbo selected
* 2 feet of fire wrap heat sleeve
* FD heater core hardline replacement with new hose and clamps
Please contact our Sales Manager Shawn Christenson to place your order. 763-753-9939
shawnm565 is offline   Reply With Quote
borgwarner efr, turblown, turblown.net
