| Introduce yourself!! Tell me something about you and your history with rotary.. |
#1 | |
Don Mega
WELCOME! First off the meet your stated objective STREET CAR that is drag capable. WATER INJECTION and pump gas is ALL you will ever need. I have many of them that embarrass full methanol drag only set ups! 13B street port (13B-RE or REW ported out to be RE spec runners with RE inlet manifold.) BW S369SXE (true 900bhp capable), fitted with Tial rear housing pump gas and RR water injection will do in that car 8's and 160mph range easily, simple reliable real street set up. Welcome again Other parts to use. Tial V60 Life Racing F88 ECU (full knock, lambda, traction control etc) ALL WORKS! not internet hype but as used in LeMans 24hours! I have fully developed rotary engine calibrations and full support for these for anywhere in the world 4 x 2000cc injectors RR water injection system Steel Science apex seals RR coil on plug and M&W pro drag street RR CDI set up All proper items not a microwreck or 400 add on dildo boxes of cheap nasty electronics
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 12-11-2015 at 07:34 PM. |
Don Mega
4 ports, RR street ported is all you will ever need. There is allot of total bullshit out there and much wasted effort spent on total crap! like extra peripheral ports and totally butchered housings.
I have the largest and most correct validated data base of rotary engine knowledge anywhere in the world on porting and turbocharging, once you know how to separate the fact from bullshit (takes more than a couple of days on the dyno lol) it is real easy to see that you need nothing more than a correctly done street port and selecting the best OE inlet manifold, that currently is the 13B-RE or COSMO, the REW is a much better engine base and it is easy to port out its inlet runner shape to accept the RE inlet manifold, this then makes the best base engine for your application. On a real simple level looking at the highest boos levels on the turbo I told you about above for street use and using a Tial 1.06A/R V band housing on a basic linear scale as you increase MAP 1bar 225bhp (0 boost) 2bar 450bhp 3bar 675bhp 4bar 900bhp (43psi boost) You actually make more power at the lower MAP levels due to higher Ve in those ranges but the above suffices to paint the picture for you. This is all set up on very conservative engine calibration that will live for years on gas and water injection, dozens of cars running this way, all proven and NOT ONE E85 or ethanol FUCK UP NIGHTMARE ever to deal with! EVER! Simple Reliable, world leading.
Thank you for all of the information. That will be a great help. Sgt Frank not to sound like a smart ass, but why would a TH350 be more of a problem than a Mazda auto ? I was planning on a 350 or a glide with a high stall and a trans brake. But like I said I no nothing about Rotary Engines.
Don Mega
Here is the power torque curve for the combo I suggest to help you mate up the TC.
#5 | |
Professional Stick Poker
![]() The lightweight VW chassis will help a lot, but I would hate to see you disappointed with your results if it doesn't meet your goals. If you are planning to be competitive you might want to talk to the guys at Bola De Humo Racing in Kansas City. They have a seriously fast first gen that they campaign and the actual real world experience in what it takes to put a rotary into the low 7s.
Don Mega
Ebola Da Homo has ZERO experience in making a road car fast, REAL ROAD CAR@!
Any homo can slap on a microwreck and methanol or race fuel and blow more smoke than a cheech and chong movie shit box!@ there are hundreds of ass clowns who can do this, it takes ZERO brains or any skill to do it, just go to any drag track and see the morons (plenty to choose from). Or do you want an engine that you can drive anywhere and still lay the smack down on the dunce cap logo microwreck brigade????
