IT'S ALIVE!
I measured the thickness of water pump housing to front iron gasket and the shims supplied by Mazdatrix (1757-15-106). Both came out to approximately .020 in. thick so it was looking good for using the shims. However, when I test-fit everything together I was getting a small gap between the water pump housing and the front iron with the shims installed. I was easily able to fit a .005 in. feeler gage in there and a .010 in. gage fit with some effort. For my application my conclusion is the shims should not be used. My hypothesis is that is the difference is in the water pump housing not the front iron, but I'd need to test all the other possible combinations to confirm.
Rep Power: 20 ![]() |
Did you measure with or without the housing gasket?
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
IT'S ALIVE!
The gaps were checked with everything installed and torqued "reasonably tight." Without the shims I had complete contact all the way around at the housing-to-iron interface. Without the shims a I did have a small gap at their location (<.005 in.) but I think this would disappear when the housing was properly torqued down.
Mazda does list another P/N for the shim (there's a VIN split for the S4) and perhaps it's a thinner design. I may order those to check in the future since I won't be starting the engine for some time and it's pretty easy to install them. |
#4 | |
IT'S ALIVE!
Bookmarks |
