It is possible...
For the turbo, if it's making boost, it's highly unlikely that's the culprit. The TPS could be the problem, but it'll hesistate like a MOFO if it's bad enough to slow the car down. It's most likely other things like: * wrong ignition timing * wrong spark plug wire positions * worn spark plugs * ignition misfire * clogged fuel filter * too much fuel * clogged cats, if you still got them * bad thermo sensor * big intake leak, but you will usually hear this -Ted |
#2 | |
Rep Power: 21 ![]() |
