Old 08-13-2015, 08:52 AM   #1
It all seems like it might work. Same width between the rails for the front subframe, rack, suspension arms, sway bar is all contained as a unit. Only serious modification would be to lower the shock towers. For the rear, there is tons of room back there. The fuel tank is in the trunk, and there is nothing else back there. The rear is also a self contained unit. Nothing except the strut tops is 'outside' the assembly.
