Professional Stick Poker
... and leading coil is mounted.
built a bracket to bolt where the original coil went ... leading coil bracket by Kevin Frank, on Flickrmounted the coil ... leading coil mounted by Kevin Frank, on Flickrand a picture of the whole ensemble. coils and battery by Kevin Frank, on Flickr
#2 | |
Rep Power: 17 ![]() |
Can you pull the plugs with it in the engine bay..
Yep, yep, one of the first things I looked for, accessibility to the plugs. Admittedly I probably shouldn't do any bulking up on the forearms to get in there, but I can reach them.
#4 | |
So easier access than an Rx8 good deal!
OK, OK, I'll go get pics. :grumble, damned nuisance neighbor kids, grumble:
#6 | ||
