Paint stripper doesnt work...
Ok, so because I'm swapping in another engine, I decided to strip down my nasty grimy engine bay, clean it, and repaint it in 500 degree Hi Temp white.
I was fine on the stripping off all the parts, and got most if not all of the grime out. however, when I went to strip the paint, the paint stripper just isnt working! I did it per instructions, spray on, and let sit for 15~30 min. Well, this is how it turned out after some scraping, and then another coat a day later and a power wash. (note: I did not wash the old stipper away after the first time, and just sprayed over it the second... would this affect anything? Here's some pics: ![]() Also, I cleaned up the shortblock I am putting in, and I must say, it looks mighty clean! ![]() ![]() ![]()
Are you using some kinda EPA/CARB/water soluable paint stripper?
Go for the nasty "aircraft" stuff that'll take you skin off! -Ted |
That's what I used! I bought clean Strip Aircraft remover aerosol can, and sprayed the hell out of it, and all I got was this.
I will try again tomorrow... but this really pisses me off, I thought I would start painting shit by now!
Rep Power: 22 ![]() |
No aerosol cans.
They are diluted. Use the TAL Strip in the metal jug (aircraft stripper, you can buy it at Advance Auto Parts). Wear a glove and mask, and watch the paint disappear.
crash auto?fix auto
Word, the aersol stuff wouldn't take bug grime off a windshield.
Buy the jug, apply with a brush. It'll bubble that shit off like nothing.
ok. will do. I'm gonna try to return that pos crap and say it's defective or something.
Yeah, I was gonna say...
![]() Just like "carb cleaner"... The carb cleaner in the spray can is totally different than the carb cleaner in the gallon can! -Ted |
Hmm, really? I use aerosol carb cleaner just fine for what I need it for... I bought a gallon jug of it once, it wasnt really effective on this puch moped carb i was trying to rebuild.
also, carb cleaner does wonders for cleaning off the really nasty grime you somtimes cant get off with just orange hand cleaner.
#9 |
crash auto?fix auto
Also, a good tip when trying to strip a panel:
Take some rough paper (40grit) or an old piece of grinding disc (~26 grit) and scuff the whole surface up qiuckly. You don't want to sand it all, just cut through to the metal is a few areas to allow the stripper to more easily "bite" under the paint. It will also make it easier to scrape off afterwars since you can start from a scratch where the stripper has cleaned it to metal.... |
#10 |
Thanks for the tip! I just got back from summer classes and was right about to go and work on the car!
I gotta finish this bizatch already!
