#46 |
#47 |
Rep Power: 20 ![]() |
Oh, OK! My dad used to have one of those, I'll see if he still has one or at least access to one.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#48 |
Finally the issue I have been dealing with since before DGRR has been resolved and the car is running now and did so for more than one day! The issue was with the trigger sensor connector polarity.
After receiving the harness I got all the wiring back the way I like it, again. A little more tuning and the car should be a reliable driver. Got her all cleaned up this week and ready for the next joy ride Just have to pass emissions to renew my registration and I'll be able to drive it anywhere.
#49 |
Dibs on the first burnout!!!
-75 RE_W_PU - -76 Hercules W2000 - DGRR 2012 3rd place Old School -75 Hercules W2000 MSO - DGRR 2011 Peoples Choice - April 2011 Rotary of the Month ![]() -Rotary snowmobile powered go kart - DGRR 2012 Peoples Choice - RIP |
#50 |
Congrats!
![]() Did you find this with the O-scope, and was the trigger sensor wiring leads just reversed (+/-)? |
#51 |
Thanks!
No, I couldn't find a grandpa local that had one of these prehistoric machines LOL Yeah, the wires were reversed.
#52 |
Also, I didn't find this. . . I had no idea what else to inspect and I would have never suspected anything like this to be incorrect so I sent it back to be looked over/repaired.
#53 |
I want to celebrate like I did in the parking lot years ago when you lived by the school! That's the kind of celebration I deserve!!!
#54 |
IT'S ALIVE!
Awesome to read you got everything sorted out. Little stuff like that is always the last thing checked...
#55 |
Yeah, it's unfortunate but I'm just happy it's over with!
#56 | |
Rotary Masochist
Zach took the time to pull the harness I had built for him out of the car and ship it back. The root issue was my bad ASSumption that connectors from two different manufacturers would be labeled the same. They weren't. So the two trigger wires on the VR sensor were revered. So after all of the hair pulling the screw up caused Zach, it was a 15 second fix. Lesson learned and hopefully a mistake I won't repeat.
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
#57 | |
#58 |
Rep Power: 13 ![]() |
glad you got it worked out, we need to go on a cruise now
#59 |
Yes sir, that would be nice. Ideally I would like to have more tuning done before driving outside of town. That, and most importantly my tags are expired so I'd like to have a fighting chance at emissions testing before I waste the time and money. I'll get with Jacob sometime.
#60 |
Chris helped me out tremendously with making my two gauges (pressure & temp) perform two different functions a piece by drawing up a color-coded wiring diagram as well as suggesting which switches to use. I had been putting this off because I was afraid to cut up the gauge harnesses without being completely sure where each wire goes.
Thursday I started trimming the gauge harnesses and adding connectors and switches to both. I got it completed yesterday, everything worked perfectly. I added small labels to the mount to use as a cheat-sheet till it's commited to memory. I'm using the temp gauge for oil and water. Problem with using it to monitor coolant temps was that the ECU had its own dedicated sensor for coolant temp so an additional hole needed to be added for the gauge. . . I used one of the coolant bypass ports for the extra sensor by drilling and tapping NPT threads. I've heard plugging the bypass ports is a no no but these ports have been inactive forever without any problems (that i'm aware of. .) The pressure gauge I'm using for both oil and fuel. No issue here other than the need for a pedestal to mount the two extra sensors for monitoring the oil. I decided to use the FFE 13B REW pedestal that will work on a 13B when the REW's oil cooler hole is plugged, I found the plug on eBay for ~$5 (not pictured).
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 Last edited by FC Zach; 06-12-2015 at 01:00 AM. |
