DGRR Archive Threads from Previous Deals Gap Rotary Rally Events. |
#16 |
I SEE DEAD PEOPLE
Can't wait to see this sexy mofo again^^^
VIN-AUTO Rotary list of Fails below: 86 mazda rx7 csp 61 N/A= because RACECAR 87 mazda rx7 t2 with 13b-re cosmo GT42= FKN RUNS!!! 03 Dodge Viper SRT-10 Vert 06 dodge ram 2500 Megacab turbo Cummins=puller 16 MB ML350 |
#17 | |
Rep Power: 22 ![]() |
Plan C is a go, but it hasn't arrived yet! Dammit Amazon!
#18 |
Rep Power: 10 ![]() |
Fuel Cell?
#19 |
Professional Stick Poker
55 gallon barrel in trunk?
#20 |
No $$ for one. Unless Speed1 wants to sponsor and hook a brother up.
Not enough HP to carry. ![]()
#21 |
#22 |
Waffles - hmmm good
Poor mans fuel cell, line it with a garbage bag.
![]() Hope the POR 15 works, I want to see this at DGRR.
#23 |
#24 |
counting down till DGRR
-74 RX-4 -84 REW GSL-SE Past rides -05 REW Swapped RX-8 -93 FD base |
#25 |
This might work for test firing and set up. Lolz.
POR-15 kit has FINALLY been shipped.
#26 |
Home-brew Rotary
Its so refreshing to not have an exhaust leak!
FIXED!!!! So i ditched the RB mufflers and put on an N1 muffler that i bought from Reese. I Tig welded the pipe from the N1 to the RB presilencer, Because the stud that I cut short from along time ago was not providing the tightness to properly seal, and of course the studs won't come out. So the whole system only has 2 gaskets, hehe. I also made a homemade silencer for the exhaust tip. 4&3/8" down to 2&1/4". The exhaust has a nice deep sound to it. Love it.
'89 RX7 GTU, half-Bridge-port S4/S5 NA, E6K, Full RB exhaust, weekend warrior. '83 RX7, The "this might take awhile" project. '87 RX7 GXL, Rest In Pieces. '98 Subaru Impreza Outback-sport, rx7 rescue vehicle, down for repair. '94 Ford Ranger, daily. |
#27 |
POR 15 fuel tank cleaner/sealer kit is being delivered today!! Wednesday I am taking the fuel tank to work, and using our 300 degree burner pressure washer to blast it out, then use the kit on Thursday when I'm off.
Wish me luck!
#28 |
Luck.
#29 |
Just had an interesting conversation with one of the guys at POR (Advanced Coatings). They said that if after the tank is pressure washed and cleaned, if there are no leaks, pinholes, or traces of rust in the tank, it isn't necessary to use the Metal Prep or Sealer.
If that is the case, it just cut down my work my about 70%. Burning the tank today, cleaner tomorrow.
#30 |
Early success!
Brought the tank to work today, and used the pressure washer with a burner to blast out all the scale and sludge, BEFORE the POR kit is used. 75% of the scale and nastiness is GONE. What remains should easily be eaten up by the POR Marine Clean, which is happening tomorrow. No pics, since my phone is at 10% and failing.
Bookmarks |
