Old 03-26-2015, 04:11 PM   #1
More stuff:
Did some work today, with some much needed help from Charles.
-Cleaned up the engine harness. Now there is only about 5 or 6 wires left.
-Wired up the electronic dizzy and coils
-Wired up the S4 alternator
-front clip back on
-fuel pump and lines installed
We put power to it for the first time in at least 16 years. Amazingly, nearly everything works.
Here's a list of what still needs to be done.
-figure out why I have no brake lights
-figure out why the wipers/washer doesn't work
-bleed clutch
-fill rear end
-fill trans
-fill oil
-fill coolant
-clean tank (happening Sunday)
-fix oil leak at oil cooler thermostat
-figure out why driver side mirror doesn't work
Should be all buttoned up this weekend. Knock on wood.
