				Rep Power: 19 ![]()  |
			That's some piece of work!
	You'd be amazed at how much more efficient everything cools now... If anything, it might be too cold! Pat yourself on the back for a job well done... -Ted  |
				Rep Power: 16 ![]()  |
			Nice job!
	![]() Is your radiator & oil cooler still located in the stock locations, using the stock brackets? Too lazy to back-read, but I seem to recall you're using an aftermarket AL radiator & stock oil cooler in stock locations, but probably yanked out the A/C condensor? If you drew up a diagram for cutting out the sheet metal pieces, please post it up!  |
