Show your rotary car build up. Show off your Rotary Car build! |
#1 | |
Can't.Make.Up.My.Mind.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
Professional Stick Poker
I think that part is mainly for the drifter crowd to get lots of negative camber. If they accept stock positioning they should work. I believe MazdaTrix also sells the stock replacement arms with the ball joints already pressed in.
they do indeed.. for $77 a side. Ill probably be ordering them soon. I need to clean up the hubs first too. I wanna get all the front end stuff taken care of while i have the front of the car up on stands.
#4 | ||
Rep Power: 10 ![]() |
However... looking at Gunny here... how would those affect roll center... I'm failing to see that... Quote:
Wait.... wut? I'm not seeing those... I'm just seeing the replacement ball joints...
#5 | |
![]() http://www.mazdatrix.com/hsteer2.htm this is what I'm talking about.
#6 | |
#7 | |
![]() I said the MazdaTrix ones were the stock replacement. The others were for aftermarket ball joints if they ever make it into production.
Ohyeah..... wheels and shit...
#9 |
How much do you want for the wheels?
Also... since I'm using the hubs from an S5 car do i need S5 ball joints? because if i do there is a note on mazdatrix that says the S5 ball joints only come on the S5 control arms...... ![]()
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" Last edited by project86; 01-21-2015 at 09:33 PM. |
#10 | |
I was asking $700 on fleabay and cl... got many a bite on cl but no one came through with cash in hand... No... If you're using S4 control arms than you need S4 joints. hubs/knuckles don't care which series
#11 |
I have no idea. I just saw them talking about them the other day and when he started asking about aftermarket alternatives I remembered these. I had to do a little searching to find it. I don't have much need for FC parts so I didn't really think too much about it, but they looked kind of cool so I thought it worth passing on to those that do.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 01-21-2015 at 09:37 PM. |
Bookmarks |
