Old 06-19-2008, 07:18 PM   #16
TehMonkay
i thought the gsl and the se rears were the same other than the bolt pattern?
Old 06-19-2008, 08:48 PM   #17
I am pretty sure they are very similar. I believe they share the same bearings and seals. The GSL-SE comes with LSD (once again, I think), but then again, so does a GSL. Also, both are standard with disc brakes.
I would trust a solid axle rear end to hold up to the power before I would trust an NA diff vs. a TII, but I am a gambler!!!!
Old 06-19-2008, 10:03 PM   #18
The only diff between a GSL and SE rear IIRC is GSL's are 3.90 and SE's are 4.08 and the bolt pattern difference, I believe the strength is about the same.
Old 06-20-2008, 12:23 AM   #19
dregg100
Originally Posted by rotarycrazy View Post
I am planing eventually to eather rebuild or get a SE rear end and build it I just dont think I need a ford rear end in there my top goal for the car is 300whp and no more. Inky reason for that I had a chance to experiance a 79SA that weighs in at a scant 1928lbs with 320whp wery little lag on the turbo and I mean that thing will scare the living crap out of you .
oh really, and who's car might that be?
'93 SSM Touring-S475...
'87 Tii-LS1/T56
