I have a 1990 TII rear. So are you saying I still need to get S4 stub axles? Would that mean S4 haft shafts or S5? Or are they the same?
I bought a 4.3 R&P for a S5 TII rear. Should I order pinion bearing for S5 TII? I am not doing the work. A guy who builds American racing engines and rear ends is. He isn't exactly familiar with Mazda rear but can accomplish what has to be done. I am just trying to get the correct parts to him. I don't really know what backlash is but I do know it has to be set by someone with the right tools and knowledge. Macon Motorsports is handling all of that. Last edited by Christopher W.; 06-16-2008 at 09:29 PM. |
#2 | |
Halfshafts are not same. I have came across to two different lenghts of TII halfshafts. As you can see in mazdatrix pictures, first two stub shafts are from S4 TII and they differ in lenght. Lenght does not change inside of differential, but outside. And thats where you need to be carefull about choosing right halfshaft. Longer halfshaft has to match 5 7/8" stub shaft, shorter halfshaft has to match 6 1/4" stub shaft. Using wrongly matched stub + halfshafts will cause you problems. We once used short + short and stub shafts were pulled out of diff during driving......long + long will cause unwanted pressure on the diff from side and/or could damage/break halfshaft assembly.... |
After talking to Mazdatrix they don't have real experience with this swap. They did say I need the S4 stub axles. They said there are two different length haftshafts available but didn't have anymore information on that subject.
I am not sure about which stub axles, the short or long. I don't know if that depends on which haftshafts I get. Should I first buy the haftshafts then determine which stub axles? Does anyone know off hand if there are two different part numbers for S4 TII haftshafts. Or what the length measurements are for the short and long haftshafts. In reference to hIGGI's statements above that means if I buy shorter haftshafts then I should get the longer stub axles or longer haftshafts and get shorter stub axles. Last edited by Christopher W.; 06-17-2008 at 12:03 PM. |
by looking at mazdatrix picture, u can simply assume that
S4 after VIN 608385 and ALL S5 TII halfshafts are longer : Get these S5 TII longer halfshafts and then shorter S4 TII stub shafts (S4 after VIN 608385, part number shown in picture. That should be ok. We run FD torsen in about 10 FC's so far, its most affordable LSD for us... Swap is pretty straightforward, set backslash and DONT forget to glue bolts to the ring gear (on one of our diffs they did break loose and it did not ended up good )Here are some pics from swap : http://rx7cz.net/photos/workshop56/ |
#5 | |
Then of course I would get two S5 haftshafts. Last edited by Christopher W.; 06-17-2008 at 06:21 PM. |
