Old 10-06-2014, 07:05 AM   #1
infernosg
IT'S ALIVE!
infernosg's Avatar
Yep, the canister stores air and fuel vapor from the fuel tank until it's sucked into the engine through the purge control valve. The gas tank vents through the "check-and-cut" valve. If the canister will cut down on the gas vapor vented to the atmosphere I'll keep it since I don't want a fire hazard in the garage. If not, it's a waste of weight and I'll remove everything back to the check-and-cut valve.
