Closed Thread
Old 06-22-2014, 12:28 AM   #1
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Finally done with the grinding on the left side and threw a quick coat of primer on there. I can no longer get the good 3M etching primer here, so I had to make do with Krylon. Which is why there is a color change in my primer.
Oh well. I'm not going to get carried away with paint yet. A good rattle can job will do in the engine bay until I'm done with the engine and all likely mods. I'll then have everything media blasted and use filler (or lead?) to smooth everything out prior to laying on the actual finish coat.
left wheel well 1 by GySgtFrank, on Flickr
left wheel well 2 by GySgtFrank, on Flickr
left wheel well 3 by GySgtFrank, on Flickr
left wheel well 4 by GySgtFrank, on Flickr
... and a shot of both wheel wells done and in primer. It's amazing how much faster and easier it always is to tear stuff apart rather than putting it back together again.
left and right wheel wells by GySgtFrank, on Flickr
I still have to do a little cleanup on the bottom of the right side and get it in primer, then I'll be finished with the sheet metal portion. Then back to the lower K-member/upper shock mounts. *groan* I have to put it all back together again. at least once and probably more, just to check measurements and then take it all back apart again for final fixes to both.
Yes I will get this done this year. At least until I tear something else apart and have it laying in pieces again. I suffer from a little recognized malady known as Brian Treffeisen's Disease, or CQFWI (Can't Quit F***ing With It).
GySgtFrank is offline
Old 06-22-2014, 01:00 AM   #2
chibikougan
chibikougan's Avatar
Nice!
I like me some Krylon.
chibikougan is offline
Old 06-22-2014, 11:54 AM   #3
GySgtFrank
GySgtFrank's Avatar
Nice!
I'm not too thrilled with it, but it's only there to keep the rust off until I'm finished and can blast it all back off anyway. I'm partial to PPG products for paint, but that's a whole lot more work and expense than I can justify doing more than once.
Originally Posted by estevan62274 View Post
BADASSNESS!
Can my SE be next
Thanks. I don't think you would want to do it this way. Way too many hours involved. I have worked out a few easier, faster, and better ways to accomplish something similar. You always do after the fact. I'm committed now (or maybe that's "should be committed now") and have to do it this way. It's the part about keeping it under the stock sheet metal that has really complicated things.
Closed Thread
