#16 |
Rep Power: 14 ![]() |
Okay I will try to address every point you made tomorrow.
However if that doesn't get things working I'm still gonna want to hookup a pfc just for shits and giggles. Speaking of which - any progress on the base map peter? About plugs being garbage after they foul though.. I hate being the guy who is asking for help, gets it and then proceeds to throw it back in your face but I don't think the plugs are a problem. Reason being, the "failure" point is just too consistent. Even with garbage plugs, I would expect the odd fire once it's past 2k, but there is absolutely nothing. And the fact that it cuts out at the exact same time every time just makes a "partial" plug failure seem unlikely. It's too synced. I say partial because they obviously still work fine below 2k so.. But thank you! I at least have some trouble shooting ideas now.
#17 |
Rep Power: 10 ![]() |
If your cal is setup in such a way that at 2k it goes pig fuck rich everytime @ 2k, than everytime you go to 2k it's going to miss and not fire....
I had a car with a wolf that everytime you would get to about 3k it would cut out. Give it a little more throttle and it would come back to life.... floor it and it would stumble but rev.... found out that he had the secondaries wired to the primary circuit... so give it a little throttle and there would be enough vac to pull the fuel down the runners. crack the throttle and there wouldn't be enough vac to pull the fuel out of the secondaries because the primaries had all the airflow. Crack the secondary butterflies and viola, enough airflow through the sec runners to get the fuel into the chamber. I thought it was a tuning issue until I realized that everytime the secondary throttle cracked it would come to life.... point being it wasn't a tuning issue but a mechanical issue, yet it was always repeatable. Seen the same with tuning issues because of fucked comps or just about anything else..... it's usually going to be repeatable regardless of the issue at hand. Needs moar data.... make sure ecu isn't cutting something, make sure ecu has good signal at that point, make sure plugs are good, tune to 12.5-13 @ idle by adjusting base fpsi, rev it up see what happens. Also.... make sure the thing is up to operating temp before trying to rev....
#18 |
#19 | |
Rep Power: 17 ![]() |
OMP limp mode?
Also your hot bod is on display might wanna limit the photo sharing.... Or was that on purpose? ![]() I like the interface for the link...
#20 | ||
Half bubble off plumb
Derp... lol Im really hoping this fixes your issue... J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
#21 | |
![]() And yeah its omp related im guessing. only thing.. it says in the bottom that rpm is limited to 4500 rpm but cutting closer to 2000. It does overshoot to closer to 3 so it might cut earlier than 4500 just so it doesn't overshoot past that but who knows. This is obviously a problem and hopefully the big culprit im looking for. I agree the interface once you got used to it would be pretty nice though. THeres a learning curve for everything though, it usually takes me a few mins to find where what i want to be displayed is but for sure once you're familiar with it its a clean layout.
#22 |
Likewise. It will fix something but i'm hoping it fixes everything
#23 | |
Haha it was the 2nd pic on the scroll through. Not complaining about man meat
![]() I do believe rice still runs a mech OMP so it makes sense.
#24 |
Don Mega
I have sent instruction of software changes needed, touch wood no more limiting!!!
#25 |
I'm going to be the first to say though.. Let's assume that this does in fact fix the problem - a PFC would have made it work
#26 | ||
