Old 06-06-2014, 05:48 PM   #1
Let me get this straight...
You want to mount your coils onto something other than directly onto the engine / spark plugs?
You don't want to use spark plug wires?
Does that sum everything up?
Did I miss anything?
Old 06-06-2014, 06:12 PM   #2
chibikougan
chibikougan's Avatar
http://www.rx7club.com/3rd-generatio...-packs-864760/
I believe you have to cut down the spark plug also.
Need a trigger and something to drive 4 2 wire coils.
Build a custom mount.
Good Luck
Old 06-06-2014, 07:30 PM   #3
sen2two
KTEC
sen2two's Avatar
I just tried to draw it up in SolidWorks so I can post a 3d rendering, but of course the program is giving me an error. pictures are worth a thousand words, and even more in this scenario.
What I am trying to do is, make a mount that will be attached to the engine. This mount will hold the coils/igniters directly in front of the spark plugs also acting as a heat sink. The spark plugs will be connected directly to the coils through a boot that I will make, since I do not believe they make this type of boot.
Please note that this is not for a fuel injection motor. These are 2 Blaster SS coils (8207) using HEI igniters, with a 85 distributor (TFIDFIS). Using with no trailing ignition at all.
what I have:
What I had:
Old 06-06-2014, 07:35 PM   #4
chibikougan
Did you ask just to tell everyone what you are going to do?
Seems like you have it figured out.
Good luck
Old 06-06-2014, 08:18 PM   #5
sen2two
KTEC
sen2two's Avatar
Good luck
I posted thinking that maybe somebody would know where to get one of the boots to mount a coil to a plug. I never asked a question on how to do it or if it would work. Only where to get the part.
what I have:
What I had:
Old 06-06-2014, 08:38 PM   #6
chibikougan
Here
http://www.google.com/#q=coil+to+plug+boot&tbm=shop
