Old 05-09-2014, 07:07 AM   #2
I'm guessing you're Billy's friend and this is a white 'Vert right?
If all this is true than I'm the one that tuned that car, Barry put it together for the most part from what I know. We didn't do a lot of work to it explaining the lack of paperwork.
We fought voltage, ground and electrical issues in that car for the LONGEST time. Such to the point where I had to show Kyle how to rewire the headlights to make the HIDS turn on because even with the car running they weren't getting enough voltage to turn the damn things on, like less than 10V! I dunno what happened to that car before we got it, but it was a mess and we never found all the problems.... I told Billy to tell you my offer.... when you wanna make that thing a terror and drive like a stock car, let ME know
Anyway, onto your problem.... I've found that microwrecks have a lot of problems, when it comes to ignition breakup though, most of them can be solved in the following way....
Make sure the engine has one good solid ground. The best way to do this is straight from the battery with an acceptable ga, like an 8 or a 6. Generally what I do with these boxes is use an m8x1.25 stud on both rotor housings. Generally studding the rear on top where the TMIC framework and all that jazz bolts. Daisy chain that to the front rotor housing. From the stud on the rear rotor housing, ground the box itself.
Next, make sure that the coils themselves are getting REALLY good clean power. On this particular car I remember having breakup problems on the dyno, I specifically remember this because... and I hate to tell you this because I remember the conversation with Dave.
I couldn't find anything really wrong with it except some kinda weak voltage to the coils. We ohmed out the coils and half of them were bad. I replaced them and the breakup went away. When I asked if I should spend a few hours rewiring them to hopefully prevent it in the future, Barry didn't want to spend the money because... he was probably going to sell it anyway... sorry. So more than likely the coils are bad again because for whatever reason, the voltage in that car sucks donkey balls.
My offer stands man.... hit me up via PM's and we can chat about making that thing a clean ass engine bay, runs like a fucking terror and retains some bone-stock driveability.... I seem to remember that engine being a VERY mild porting, but microwrecks have no idle control along with lacking other things..... IMNSHO microwrecks belong in ITS n/a race cars and that's about it.... Certainly not a turbo rotary when a failing TPS or a few pressure bounces can pop a motor on those things based on the way they calc fuel and load.........
