|  05-01-2014, 11:33 AM | #1 |
| Lifetime Rotorhead Join Date: Apr 2010 Location: Elkton, MD
				Rep Power: 16  |
				Turbo oil feed restrictor question
			During DGRR, I found out that my new BNR turbo (stage 2) oil smokes when letting off the boost while running hard in the twisties and during the steeper uphill climbs; there's little to no smoke while doing the same over straight, flat & level roads. I'm using a -10 AN plumbing for the turbo oil drain, which follows the stock oil pipe path to the front cover. After discussing the symptoms & my oil drain setup with Bryan at BNR, he suggested I try a 0.060" oil restrictor in the feed line, as close to the turbo oil inlet as possible. I'm currently using the stock S5 turbo oil feed hardline plumbing which has no restrictor. So I was thinking I can easily fabricate a 0.060" restrictor plate out of some 1/16" thick AL stock that would simply install under the stock pipe flange on the turbo side. Other than needing 2 gaskets to seal up the assembly, does anyone see a downside to this plan? Only thing I can see is I'd be introducing one more potential point for a leak to occur, and the stock hard lines may need to be bent a bit to make it fit properly. I'm not too concerned with the latter as there appears to be enough tolerance/slack in the stock hardline to accept the extra 1/16" restrictor and gasket on the turbo side. |
|  05-01-2014, 11:47 AM | #2 |
| RCC Addict Join Date: Mar 2008 Location: Honolulu, Hawaii USA
				Rep Power: 19  |
			Before it gets that messy, we should try and confirm that this is the case? How is your emissions plumbed in right now? I'm assuming the stock emissions have been removed or modified by now? I'm talking specifically about the "PCV" system. As a quick-n-dirty test, remove the oil filler cap and see if the problem changes? If the smoke disappears, you have too much positive pressure in the "crankcase". As for your oil return system... I'm assuming you're using -10 fittings and adapters? Normally, a -10 line is fine, but it's the more restrictive fittings and adapters that neck the system down that causes a restriction. As a rule, I try and fit a minimum -12 set-up for any oil return system. Else, the stock system that uses flanged / "barbed" fittings is usually superior in terms of cross-section area for the oil drain due to this fact... -Ted |
|  05-01-2014, 11:48 AM | #3 |
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  |
			Hey Pete, few options here As we discussed at DGRR you could weld up the banjo bolt and drill a .060" hole in the banjo bolt. There are some fittings that you can purchase that allows you to convert the top of the turbo to a -4 fitting and easily allow you to change fitting sizes, you will need to build a new feed line but that is really minimal effort. Hell, Verocious can actually build a line for you when you order parts. Something like this from Verocious Motorsports - http://www.verociousmotorsports.com/...e-1-8-NPT.html and couple it with something like this - http://www.verociousmotorsports.com/...r-Fitting.html that allows you to easily swap out the restrictor size without breaking the gasket seal on top of the turbo. That's probably the most elegant way to go about it. I have seen plenty of people take a soda can, cut it out, and punch a .060" hole in it for a restrictor.... they almost always leak for one reason or another. I vote the first or second approach. Second is the easiest for swapping different restrictors.
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- |
|  05-01-2014, 11:49 AM | #4 |
				Rep Power: 10  |
			Teds right though, the quick and dirt test is pull the oil fill cap off and I suggest put a sock and a racing fastener incase some oil decides to creep up the neck.
|  05-01-2014, 12:10 PM | #5 | ||
				Rep Power: 16  | Quote:
|  05-01-2014, 12:41 PM | #6 | ||
|  05-01-2014, 12:48 PM | #7 | ||
				Rep Power: 10  | Quote:
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- | ||
|  05-05-2014, 04:52 PM | #8 |
				Rep Power: 16  |
			Quick update - I went ahead and built up the restrictor plate this past weekend more or less as described. Difference is I used 1/8" thick AL stock and a couple of longer bolts to securely mount it. The thicker restrictor plate still fits fine with the stock oil feed pipe and is leak free. The other difference is since I didn't have a drill bit small enough for the 0.060 hole, I used the smallest bit I had on hand which was 3/32" = 0.09375". Figured for test purposes, I'd rather flow more oil than less. Anyway, after a test drive, my smoke screen seems to be gone, and the turbo doesn't sound any differently when it spools up & makes boost. Need to get the car into some good twisty roads and steep hills to see if these results are conclusive in high-G situations though, as my test drive was over relatively flat & boring roads. |
|  05-05-2014, 05:44 PM | #9 |
				Rep Power: 19  |
			Isn't this a compressor upgrade on the stock center housing? Isn't the stock center housing have some kinda built in restrictor? Anyways, I wanted to comment on the "bigger is better" notion... Actually, the reality is opposite. With the kind of engine (oil) pressures we run, it's closer to 100psi or even over. Smaller is better. What happens if you go "too big?" I knew a guy who tried to run a -6 on the oil feed into the turbo - some Garrett T4. He ended up spinning the front (stat gear) bearing, because too much oil was being diverted from that area - notice the turbo oil feed primarily comes from that area. So, yes, in this case, more restriction is better than more flow... As a rule, don't run anything larger than a -4; a -3 is actually better for the turbo oil feed, in this case. -Ted |
|  05-06-2014, 05:37 AM | #10 | ||
|  05-06-2014, 06:22 AM | #11 |
| Rotary Masochist Join Date: May 2008 Location: Floyds Knobs, IN
				Rep Power: 18  |
			I've always used these with journal bearing turbos.  If you had an unrestricted feed, it's no wonder you had issues. http://www.atpturbo.com/mm5/merchant...Category_Code=
				__________________ _______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
|  05-06-2014, 11:36 AM | #12 | |
				Rep Power: 19  | Quote:
 I guess I missed that part of the conversation... That will do it. Glad you figured this one out! -Ted | |
