					Originally Posted by  RETed
				How is your emissions plumbed in right now?
I'm assuming the stock emissions have been removed or modified by now?
I'm talking specifically about the "PCV" system.
As a quick-n-dirty test, remove the oil filler cap and see if the problem changes?
If the smoke disappears, you have too much positive pressure in the "crankcase".
 I still have the stock "PCV" plumbed in and fully functional. Did the quick & dirty oil fill cap removal test and there was no major difference.
				As for your oil return system...
I'm assuming you're using -10 fittings and adapters?
Normally, a -10 line is fine, but it's the more restrictive fittings and adapters that neck the system down that causes a restriction.
As a rule, I try and fit a minimum -12 set-up for any oil return system.
Else, the stock system that uses flanged / "barbed" fittings is usually superior in terms of cross-section area for the oil drain due to this fact...
 I was concerned about the drainage issue when I built this up, and went out of my way to find AN fittings that are designed with minimal restriction relative to the -10 AN hose ID. The fittings I got do neck down a little, by approx. 1/16" relative to the -10AN hose ID, and couldn't do anything about those, but I was able to drill out the AN male drain flange so its ID matched up to the full -10 AN hose ID. Without boring that fitting out, it would have necked down from like a -10 to like a -8.
