Don Mega
meh............. while I understand the frustration, 15psi is like the lowest boost ever anyway? you run that in 1st gear, then 20psi second, 30psi 3rd, 45psi onwards in 4th and back down to 30psi in 5th so you don't break the gearbox.
I am different though, 15psi is very low power setting regardless of porting type.
