Old 02-06-2014, 09:24 PM   #1
sen2two
KTEC
sen2two's Avatar
Not sure about my pump jets. I haven't started the car yet (on this tune) since I am building the turbo manifold right now.
37mm chokes
3.2 Glass ball needle valve
60f10 idle jet
120 idle holder
195 main
150 air corrector
f-3 turbo e-tube
what I have:
What I had:
Old 02-23-2014, 08:50 AM   #2
730RWHP12A
37mm chokes
60f10 idle jet
120 idle holder
195 main
150 air corrector
f-3 turbo e-tube
your going to need at least a 65 or 70 idle jet, and unless your turbo is tiny a 190 main jet is wayyyy too small.. start rich, not lean. i would drop in some 230 main jets.. what size turbo are you running? you have the black solid float i hope.. where did you get the carb hat?
rotaryshack.com
Old 03-17-2014, 07:26 AM   #3
sen2two
KTEC
sen2two's Avatar
The turbo is a Holset HC1. Similar to the hx40 but much smaller hot side and slightly smaller compressor side. I only plan to run 10-12 psi on this set up.
I made my own carb hat. And yes I have the black float already.
what I have:
What I had:
