new front and rear shocks. only 1 front and 1 rear pictured
new key inside door weather strip seal. the ones that go all the way around the door and window frame. i ordered 2 for each door. they tend to rip easy over the years....want a back up set for years to come before they are no longer available. driver and passenger inner door handle cups and door pull cups. was told mazda could no longer get the passenger side in grey so i got the driver side. blackdragonauto.com happened to have the passenger side in grey but not the drivers....so i lucked out!!!! outer door window seals...both doors
www.speed1allentown.com |
every coolant and heater hose
transmission rebuild kit center part of targa band after being polished....didnt feel like unwrapping the sides for the pic engine rebuild kit exedy factory clutch kit
www.speed1allentown.com Last edited by budfc3s; 01-28-2014 at 10:13 PM. |
found a used but in very nice shape rear hatch latch
new hood prop clip hard clutch line off master stainless clutch line brake master rebuild kit clutch slave rebuild kit new trans mount coolant hose i left out of the other pic energy suspension full bushing kit engine rotor rebuild kit...all the rotor metal parts and bearings..etc etc adjustable alternator bracket have new front shock tops and all new steering components at work...will take pics as its put together
