Old 12-30-2013, 12:14 AM   #1
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
I'm thinking for my future single setup of going with a manifold much like Rice's short as possible but utilizing the IWG BW to keep things simple, less potential failure points and compact, one issue will be that my car is RHD, but i think ifI got the compressor in hand and had a manifold locally built, I *think* (or rather, want to think) it can be done...
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 12-30-2013, 01:21 AM   #2
RICE RACING
Don Mega
RICE RACING's Avatar
J.
Without wanting to read like HC!
Flow priority is far more important than shortness of pipes. The BIG problem you have with short manifolds is heat, fitment, durability.......... nothing dies faster than a short manifold and its allot more stressed than a longer one I find.
The turbine entry flanges do not last very long, especially on a divided unit, they warp and the center section gets eaten away and good luck keeping a gasket alive long term there too.
On turbo rotaries for a while now I have not bothered with divided entry turbine housings 1) they are not durable 2) they are a nightmare to keep a gasket up too 3) they are not really needed much for turbine response 4) they are way too heavy!
For rotaries the single entry Tial turbine housing is the only thing that is durable and will last I have found.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-30-2013, 02:18 AM   #3
Mitchocalypse
Mitchocalypse's Avatar
Mitchocalypse is on a distinguished road
What's your definition of durable? Like holds up well for people beating the shit out of their cars every weekend at the track? Outlasts the engine? Lives through a few oil changes?
Mitchocalypse is offline   Reply With Quote
Old 12-30-2013, 04:26 AM   #4
RICE RACING
Don Mega
People's definitions are very different especially on the internet.
The problem with turbo rotaries used in road cars is if it is set up to be efficient then it will run a high exhaust gas temperature. When you run it at 0.9 Lambda say and at a constant 100kmh you will see a high temperature and as a result the exhaust parts start to eat them selves (as you see on any turbo rotary)... ever seen what a FD3S turbo manifold looks like? Basically after 50,000km road use only these parts are scrap.
On a single turbo I have never seen any manifold last more than 30,000km (or 15+ BDC and HC engine rebuilds!). These effects get compounded if you do any sort of real power utilization (say 2% duty) at full load and power.
If you add power to the equation then its even worse as the effects are worse, high temperature combined with high pressure and cycling of temperature from high to low, pre load on the metal gasket diminishes over time then they get eaten along with the mating flange surfaces = in the end a fucking nightmare. The only things that work are gasket less, while they are not perfect they are 'durable'.
I got sick and tired of resurfacing all types of manifolds (machining is my profession among many!) and seeing all of this shit over the years. This is why rotaries are fucked! the same problem occurs in piston cars but the time is about triple to the time of failure!
p.s. most people never talk about this cause they NEVER have owned them long enough or had an engine last that long LOL....... it is an issue, I'm sure I am not the only one to experience it
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
