Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 12-14-2013, 11:25 AM   #1
Monkman33
Still Building my FD
Originally Posted by Ubaru View Post
Sweet, I'll be rebuilding my 12a. Gonna port an polish it an add a four port injection system with a computer that will run off the distributor. Trying to get the 1400 bucks is the only hard part, got all the parts located an i have a friend. Gonna consider a different oil filler because unless i run a hood scoop the upper part of the injection system wont fit under the hood unless turned sideways. the thing looks draft style. throttle body at the head and injectors down low. im still figuring things out.
These ones are pretty specific to the FD. The baffle is oriented to match the flange of the oil filler neck. So the only way for these to work for the 12a is if your flange falls in the same bolt pattern range and has the same orientation. if you pm me, we can work out the details. Or get a hold of me when the time comes.
Uh.... hi.
Old 12-15-2013, 01:33 AM   #2
Ubaru
Ubaru is on a distinguished road
ok
Still if it needs to be done i will ask this can i use the desighn to make my own ? an a question on oil cooling. was thinking of taking the beehive off and doing a chevy s10 style 4x4 after market oil cooler with a inline filter. got most of the desighn figured out, but not sure how much mass an cooling these things can take, it would only add anothe 3/4ths of a quart a quart at most. it would sit with my eventual electric fan and inter cooler set up i am plotting out.
Ubaru is offline   Reply With Quote
Old 12-18-2013, 06:54 PM   #3
Monkman33
I can't guarantee that the flange angle would match up with anything other than the 13b-rew oil flanges (which have their own variances between years). As for increasing oil capacity, I know the Xsessive oil pan adds about a quart to capacity, and larger dual oil coolers that are commonly run on FDs also add to the total capacity.
Two posts down, there is a picture of the baffle angle that I am talking about.
Uh.... hi.
