Old 05-28-2008, 09:53 PM   #1
fikren
fikren's Avatar
fikren is on a distinguished road
can't really help much as a spring install would be a fairly lengthy writeup. Only advice I can give you is you might want to look into renting some spring compressors from autozone or something. Make sure you don't tighten everything down until you get the car lowered back down and the weight loads the springs, and you probabley should look into a suspension alignment afterwards as alot of times when you mess with suspension things will be a little out of wack once its all together and your tires will suffer horribly for it. Other than that I wish you luck and you should snap some pictures if you do it, this section can always use some good DIY articles.
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
