member
I started the removal process friday and found 2 ground wires not grounded to the engine(the stock compression tube on the throttle body). I removed the upper intake to disconnect everything and the rear injector plug was barely on. With the way you had to start it, I'd say the compression was already down. It was on borrowed time.
leaving my carbon footprint....one start up at a time |
