Old 10-21-2013, 07:07 PM   #1
RXtacy
RXtacy's Avatar
Originally Posted by JhnRX7 View Post
Wow, its been over a year since an update...
Its been a busy year, but the car has not changed much. I have still been attending track days with the car, however not nearly as many as I would like. Aside from swapping out the occasional turbo cartridge on the twins I have simply been enjoying the car.
I recently had the opportunity to purchase a set of Ohlins DFV coilovers from Sakebomb Garage for a killer deal so I could not resist. I previously had Stance GR+ coilovers with 12k front and 10k rear spring rates. The ride was pretty stiff, but aside from that I did not have any major complaints. However I have been drooling over Ohlins for years so I did not hesitate to make the switch.
These coilovers are pure mechanical art. I would have almost preferred to hang them on my wall they are so beautiful. They came in multiple boxes and required assembly. This was ok though because they had the most detailed instruction manual I have come across. They provided exact measurements for spring pre-load as well as height adjustment and even damper settings for the ideal starting point.
Big weight savings with the Ohlins as well. They are all aluminum with the exception of the piston, spring, and hardware. The springs weighed more than the damper!!
Front Assembled: 9.2 lbs (each)
Rear Assembled: 8.2 lbs (each)
For comparison the Stance fronts were 12.8 lbs each. Did not weigh the rears yet.
I took the time to safety wire the dust boots on to help keep them in place.
The new spring rates are 11k front and rear. I will be curious to see what that does to the balance when i get a chance to take them to the track. I suspect it will be quite good. After my first road test I was absolutely blown away. I had known that the Dual Flow Valve tech in the Ohlins would make for a more comfortable ride, but I did not know what I was missing out on as far as handling. The ride is firm but not harsh, potholes and bumps are soaked up very well. The handling is outstanding, I took it out on my favorite backroads and I found myself going a lot faster without even meaning to. The car actually feels lighter in the turns.
I should be able to update after Nov 10th with some on track impressions... I cant wait
Love the Ohlins and the picture quality! I really need to get a real camera
Ask and you shall receive!
The FD has a perfect little cubby hole to mount the GoPro, I just wish it was a tiny bit wider so I could see the bottom of the tire. Also, there is a lot of grain from the low light. I want to find a small LED light that I can mount in there as well to see if that helps for these videos.
http://www.youtube.com/watch?v=z_hIY...ature=youtu.be
Here you go.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
ducting, ducts, fd3s, jhnrx7, track
