#11 |
Rep Power: 14 ![]() |
Been a long time since I updated.
Recently I've done a lot of work but not too many pictures because I was more focused on doing things. Few small things.. Decided to go with a link g4 ecu. It's already tuned for my setup. Might need some touching up because the difference in aussie-land and western canada climates New manifold Is also on.. Setup for 2 wastegates: ![]() Here is the initial setup: ![]() But the front most wastegate hit the steering column soo, had the raise the engine, drop the subframe, take off the engine mounts, cut an inch or so off the mount then put everything back on. NOPE. The mounts are sort of in a "V" shape, so when you shorten them, they really didn't want to line up with the holes in the subframe where they bolt so I drilled a new hole, dropped it in, and luckily it worked! Got a bunch of other stuff put together as well, fuel system, turbo, water tank/fuel cooler (which some of you might recognize) here are just a few random shots. Like I said, didn't take many. Last pic is basically where it's at now. ![]() ![]() Fast reacting intake air temp sensor: ![]() The windshield is a workbench ![]() More to come soon as well!
