Old 08-13-2013, 01:56 PM   #1
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
Originally Posted by Raksj04 View Post
I poured seafoam into my gas tank and a week later I lost an APEX seal. in my N/A FC Not sure if there is a cause and effect to that or not or if it was just time for the motor to good.
you put it in your gas, which basically was stripping the oil from the rotor housings, which is why you went boom.
The method here is to hook a hose up to the nipples on the LIM, put the other end in the bottle of seafoam/cleaner. then go in the car, hold the gas peddle to the floor (built in fuel cut in the rx8) and crank for 10 seconds. do that for each of the housings. let soak for at least an hour. do the same process with some two stroke after, then start it back up. be prepared for a lot of smoke as the seafoam and two stroke burns off. I honestly don't know how much this really works though, IMO the water is better...
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
